跳转到主内容
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
36 个问题 查看全部
Used to not hold a charge so changed battery but not powering up now
So my controller did get caught in a flood but it was working fine aside from no longer holding a charge. I opened it up to replace the battery and now it is no longer powering on even after its connected to power. Is there any other parts that could be the cause? I see some slight corrosion on pins and I'm thinking the dirt and building in there was what was keeping it getting power.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@robertadams313 Yes, looks like a bit of corrosion, etc. you do want to completely disassemble your controller. Then remove the board and clean all of it with a high grade (+90%) isopropyl alcohol. Use something like this guide 修复iPhone 的进水故障 for the cleaning. It was written for an iPhone but all the points made, are pertinent to your controller as well. Check for burned, missing or otherwise "odd" looking components. Once everything is properly cleaned give it another try. Water damage is the hardest to repair since virtually any part can fail.
这个答案有帮助吗?
得分 1
1条评论:
So I cleaned out any corrosion I found on the boards and now it’s back to turning on only when plugged in. I replaced the pins that directly touch the battery as well as the battery itself.
完成的
添加一条评论
添加你的答案
RobertAdams313 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 83
