跳转到主内容
The K-Gro PowerPro is a ridable lawnmower built for K-Mart by MTD and Murray. Released in 1997. Model numbers: 13AL452F120 (38", 12 HP) & 13AQ695H120 (46", 18 HP).
35 个问题 查看全部
New battery fully charged, but is very sluggish while trying to start.
New fully charged battery but very sluggish while trying to start the engine. Therefore the engine will not start. Perhaps the starter is weak not supplying enough power to turn over the engine?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
@ralpht101 if your mower is a K-Gro then it is quite a few years old ;-) I would imagine that there is a lot of corrosion on the witring. I would start with that. Clean the cables, and apply some dielectric grease, etc. You can determine if that is one of the issues, by applying the fully charged battery directly to the starter and then "hotwire" your tractor. Carefully, it will bypass all the safety switches. If that does not help, then it is time to rebuild or replace the starter. Rebuild kit will be available through your local small engine repair place or maybe even online. You will need to have the engine number etc. for that. Not a very complicated job.
这个答案有帮助吗?
得分 0
添加一条评论
It's also possible your compression release isn't working. That makes cranking too hard for the starter to handle. In that case, it will usually begin to crank vigorously, but immediately stop when the compression stroke happens. If it is slow regardless of crank position, and turns continuously but slowly, it's the starting system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ralph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 28
