跳转到主内容
加入维修社区 - 创建账户
针对 MacBook Pro 13"(配备第二代 Apple Silicon (M2 芯片) 和 13.3 英寸视网膜显示屏)的维修指南和说明。型号 A2338。于 2022 年 7 月 15 日在 WWDC 2022 大会上与 MacBook Air M2 同时发布。
Is it possible to replace the display?
The title says it all. Is it possible to repair the display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes, but it will require either letting Apple fix it or you can do it yourself but! Apple now serializes the display to your logic board so you must use their part as you need access to their calibration tool which will only work with the display they shipped and is a one time access as part of the Apple Self Repair program. Sadly, the newer MacBook M2 systems are not offered yet and this program is only in the states.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your answer. It looks like I can't repair it myself since I don't know the calibration tool and as you said it's not in the Apple Self-Repair Program.
完成的
@Anon User - Sorry Apple is a bit slow on its service options both for the newer M2 systems as well as other countries. If you are set, don’t forget to accept the answer - Thanks!
完成的
添加一条评论
A replacement display would work just fine. But if you ever take the repaired machine to apple, they would say they cannot “authenticate” the display; so, depending on the genius, they may allow other repairs at their discretion. Important to note that each display may have different color settings because of their batch but that has nothing to do with serialization.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anon User 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 1,032
