跳转到主内容
加入维修社区 - 创建账户
Bowers and Wilkins 出品的优质贴耳式耳机。它们通过蓝牙或耳机插孔连接到你的设备。
How is this device opened?
I have a loose connection on my right speaker and to further eliminate this issue I need to open the speaker shells first. How is that done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi
Unfortunately they doesn’t appear to be any disassembly guides online
However
Most headphone come apart in a similar way
The ear cushions usually unclog or peel off which usually reveals some screws
Once the screws are undone the driver and the housing should lift out
When lifting out please be careful as there will be cables attached
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 3
3条评论:
Does anyone know where I might get a replacement driver for the PX5 headphones?
My right one has stopped working
Thanks
由完成的
Hi!
I found Right driver on Aliexpress. But I need left one :(((
https://aliexpress.ru/item/1005009711814...
由完成的
A Teardown.
dismount ambushure (rotate counterclockwise) without fanatism. If You not need garantee by B&W. Unscrew the 4 little screws. Open driver.
https://drive.google.com/file/d/1MIEdBD2...
由完成的
添加一条评论
This is the correct way to open the Bowers & Wilkins (B&W) PX5 headphones. I found out the hard way after levering off a cover and snapping clips.
The correct way is to rotate the whole padded cover gently anti clockwise. That disengages it from the clips and it just lifts off. This example photo shows the right cover removed and the unnecessarily snapped clips on the LHS of the photo. The left side cover, which is the shown on the RHS of the photo, came off with a gentle twist.
The 4 screws to get access to the electronics are hidden underneath layer of adhesive tape like shown under the left cover (on RHS). You need to pick an edge up to peel gently off. It becomes quite easy if you use heat from a heat gun or hair dryer to soften the adhesive.
It is then easy to remove the 4 small Philips screws. You can then gently prise the module apart - the wires are short and very delicate.
Here are the electronics in the right hand side cup.
这个答案有帮助吗?
得分 3
3条评论:
THANKS. So helpful. I'd never have spotted that was tape!
由完成的
Hi. When the shells are opened- did you find the problem in wiring or electronics causing no sound in one of the headphones?
由完成的
Does anyone know where I might get a replacement driver for these headphones?
由完成的
添加一条评论
添加你的答案
Carlo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 62
总计 2,471
