AH YES, this issue. What a lot of new power supplies do is they have a "8-pin" CPU power connector, but split it 4x4 for legacy motherboards, or 2x6 (it depends on who made it, but you see both). The reason is it's cheaper for them to do that than it is for them to sell a 8 pin version, but split the connector for legacy boards, but at the same time make it compatible with high end Xeon and Threadripper boards, which need it due to the power these processors draw. While most people will not need it, once these high end boards and processors trickle down the power supplies which have it will be required to use the boards. However, the current Xeon and Threadripper boards already demand this many pins, even today. This connector is not news to those of us who came to know it from the high end secondary market.
You see the same thing with the PCIe connector for GPUs; since most GPUs are 8-pin (except the RTX 4000 series with the proprietary 8>12 pin "high power" adapter) but you can split the 2 pins and get a 6-pin connector.
You're going to see this being a need on more and more desktops, as low end CPUs largely go to die because of smartphones and tablets, and the high end chips need A LOT of power to run. I would not be surprised if there will be a point anyone who is building a high end system will have no choice but to use a high wattage (850W+ power supply) to run some of these boards and processors!
1条评论
For those novices, like me, following along, the 8 pin connector just slides apart to yield two identical 4 pin connectors! Voila! Problem solved!
由 David Rustin Lea 完成的
