跳转到主内容
加入维修社区 - 创建账户
Western Digital WD Elements Desktop USB 外置硬盘系列的维修和保养信息。提供 3TB、4TB、6TB、8TB、10TB、12TB 和 14TB 容量配置。
Power adapter replacement for external WD
Hi guys,
I lost my original power adapter 12V 1800mA 18Watts for external WD. I have another from older WD but its 12V and only 1500mA and if I connect this it's not working. Than I have some 12V 3000mA - it's from LCD screen - can I use it or it's too much and I should stick with 1800mA ?
Thanks a lot for any ideas/advice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @roboscrap
The device will only use as much current as it needs to, to operate.
As long as the voltage is the specified value i.e. 12V then using a 12V 3000mA adapter won't be a problem.
The problem with using the 1500mA adapter was that it couldn't supply enough current.
As you didn't specify the model I'm assuming that it uses an adapter with a centre pin +ve output connection as this is the most common connection.
If the adapter has a centre -ve pin output connection it will damage the HDD electronics.
The polarity of the output should be shown on the adapter case.
这个答案有帮助吗?
得分 1
4条评论:
Center is +ve so I am good to go. Thank you very much.
完成的
UPDATE - IF YOU DON'T CONNECT your external WD HDD to the USB/FireWire - it will not start up :D
完成的
@roboscrap
Probably because standard USB ports only provide max of 500mA @ 5V
Firewire provides max 1500mA @ 8V - 30V
完成的
@jayeff thanks for info :)
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 1,716
