跳转到主内容
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
21 个问题 查看全部
How do I fix a lamp with a short? The bulb flickers on and off.
my floorlamp bulb flickers on and off and only holds a light if balanced in a specific position. i think there is a short in the connection. how to fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Just try replacing the lightbulb 💡
这个答案有帮助吗?
得分 1
2条评论:
I tested the bulb, of course, on another fixture. It's fine. And the lamp is plugged in.
完成的
Then I guess you should consider replacing the lightbulb socket, but can’t say more specifically until we see an exact unit
完成的
添加一条评论
@mcb48 if changing the bulb does not help you may need to check the wiring in the light fixture itself. Remove the bulb (unplug your lamp) and take a picture of where the bulb normally sits. And one of the bulb itself. that way we can see what fixture your lamp has and hopefully can be more specific with our answer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mary Borrelli 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 106
