跳转到主内容
加入维修社区 - 创建账户
GuliKit KingKong 2 Pro 是一款配备了专利抗漂移霍尔效应摇杆的多平台控制器。它于 2022 年第一季度发布。
What size PIN Battery
What is the size of the PIN Battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@christolomia The key to these lithium ion batteries is that six digit number, in this case 803040. Those are actually the dimensions of the battery; this one is 8.0 mm thick, 30 mm wide and 40 mm long. Searching with the term "803040 lithium ion battery" will get you several sources for that particular battery; the main thing you'll need to pay attention to is the kind of connector it comes with. Here's one that sounds like it may work.
Amazon.com: AKZYTUE 3.7V 1000mAh 803040 Lipo Battery Rechargeable Lithium Polymer ion Battery with JST Connector : Health & Household
You may find other batteries that are compatible except for the connector; if that's the case you would need to change out the connector that comes with the battery for the one on your existing cell.
Note that you can always use a smaller size battery; of course that will reduce the mAh rating so you won't get as much life out of each charge, but otherwise it will work fine. I assume you wouldn't be able to use a larger battery due to physical limitations on the space the battery occupies.
Hopefully that'll get you going; let us know how it all works out for you!
这个答案有帮助吗?
得分 2
2条评论:
Necroing this post because it cost me 10$. The KK2 Pro does not use the JST PH2.0mm. It uses a much smaller size. Likely the 1.25mm.
https://www.amazon.com/dp/B0FRFY7KLH
由完成的
@jimmyhammer I'm not sure exactly what you mean by "Necroing this post", but I do appreciate you letting us know that battery isn't quite right. Note that I said it sounds like it might work, not that it was definitively the right one.
由完成的
添加一条评论
Hi,
Not sure what you mean by PIN battery but the battery in the controller is a 3.7V 1000mAH capacity battery.
The physical dimensions are 8.0mm height (or depth) x 30mm width x 40mm length
Here's an image from the ifixit GuliKit KingKong 2 Pro 电池更换 guide that shows the specifications
(click on image)
这个答案有帮助吗?
得分 1
1条评论:
Where to buy this battery? any link?
由完成的
添加一条评论
添加你的答案
Chris Tolomia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 57
总计 1,261
