跳转到主内容
加入维修社区 - 创建账户
Time Capsule A1302 型号是 Apple 于 2009 年 3 月发布的第二代无线路由器及网络存储设备。这些维修和拆解指南中的大部分信息也适用于初代 A1254 型号。
Time Machine internal drive replacement using SSD instead of HDD?
Hello Everybody.
My A1302 Model internal Hard Drive is soon going to RIP (keep getting constant errors that the Disk Image can't be created / Is damaged ) so a drive replacement is imminent.
My question is, would it be wise to replace the internal drive with an SSD ? Or should I stick with a standard HDD ?
The old drive is a 1TB and i'm going to use a 1TB drive as a replacement.
Thanks is advance for your help.
Cheers
E_
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
How it ended? Have you noticed increasing speed? Or some different experience?
由完成的
Cuál es el máximo de almacenamiento SSD que podría admitir esta unidad A1302? Gracias
由完成的
添加一条评论
1个答案
已选择的解决方案
It depends! It you are using the drive for backups then stick with a HDD as it’s cheaper when getting into the larger sizes. If you are using the drive to augment your data storage with direct access then you might go with a SSD. Even still the Time Capsules I/O speed is not very fast so you may want to get a better external drive.
这个答案有帮助吗?
得分 4
6条评论:
Hy Dan & thanks for your answer.
Seen that there's no price difference nowadays in France between an 1TB HDD and SSD I think I'll go for the SSD.
Less power consumption, less noise and as stated in a few articles here
How do I Upgrade the new AirPort A1470 to SSD?
, write speeds over ethernet are a lot faster.
This here looks like a good replacement Crucial CT1000BX500SSD1 but any suggestions are welcome.
Cheers
E_
A quick thought … if i put an SSD inside, is there a specific place a have to stick the temperature sensor back on ?
由完成的
I was thinking 4 to 8 TB for the drive as often people need deeper storage. But a one TB drive also works!
It’s not the Ethernet speed that holds you back the SATA controller logic Apple used won’t deliver what the current generation of SSD’s can offer.
Place the sensor near the drives connector as that’s where the micro-controller is,
由完成的
@danj Thanks for your insight on the subject.
Cheers
E_
由完成的
What is the maximum SSD storage that this drive supports?
Tanks
由完成的
@dani47292 - I wouldn't go to large as the WiFi and SATA logic is not that powerful in this series. A 4TB is what I would go with. Others have used 8TB drives.
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
eric 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 42
总计 5,342
