A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
Warren @www39
声誉积分: 1
发帖于: 2022年11月4日
Have a 2019 iMac 21.5 inch display. Will this display fit other 21.5 inch iMacs from 2013 to 2017 tapered case 5mm? Thank you
这是一个好问题吗?
What is you goal here? To fix an older system?
由 Dan 完成的 2022年11月4日
oldturkey03 @oldturkey03
声誉积分: 811.3千
1.2千
918
2.4千
@www39 if you just want to know if the display fits the case, then the early 2019 A2116 display should only fit the A1418 mid 2017 case
这个答案有帮助吗?
Dan @danj
声誉积分: 489千
Self employed contract worker
35
338
973
Sadly it’s not that simple! There are two variations a standard retina and the newer 4K display. These are not interchangeable. So you are limited.
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 70
1条评论
由 Dan 完成的
