跳转到主内容
加入维修社区 - 创建账户
Panasonic RQ-2102 是一款由松下(Panasonic)于 1994 年生产的便携式盒式磁带录音机。虽然它早已停产,但时至今日它依然是广受欢迎的收藏品。
Monitor port one sided?
I was wondering if the monitor port on the RQ-2102 only has audio for one side of earphones, or if I needed to see if I could fix whatever the problem might be on mine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Ridwan,
According to the Service Manual, the RQ-2102 is a monaural recorder, meaning it only records a single channel. So yes, you'll only get sound on one channel of your stereo headphones unless you use an adapter that connects that single output channel to both of the stereo channels. It's called a mono to stereo adapter; you'll need the 3.5 mm size like this one.
Monoprice 3.5mm TS Mono Plug to 3.5mm TRS Stereo Jack Adapter, Gold Plated - Monoprice.com
With one of those, you'll hear sounds in both ears instead of just one.
这个答案有帮助吗?
得分 4
2条评论:
Hi Jerry,
Do you need to adapt both sides of the cable? (my headphones have a removable cable).
Thanks
由完成的 分享
@Matías Ruiz-Tagle, no, since your headphones are stereo, the adapter will feed the single audio channel to both stereo channels in the cord, so when they get to the headphones you'll get sound in both ears.
由完成的 分享
添加一条评论
添加你的答案
Ridwan Mujahid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 716
