My iPod Classic 80G battery cable broke. Can I use it while connected
battery cable connector broke
@star75 if you have broken your battery connector off the board and are wondering if your iPod will work while the USB cable is plugged in, then the answer is: Depends.
Your USB port on your computer will not work nor will the older iPhone power adapter. An iPad adapter may work. Personally, I use a Firewire power supply for those iPods and it will work without issues.
Check the answers to this question SOLVED: The Brown connector broken. - iPod 5th Generation (Video) - iFixit Different model but identical problem and essentially the same board.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 84
