跳转到主内容
Repair guides and support for your Philips TV.
226 个问题 查看全部
ambilight ok, sound ok, image ok if lit with flashlight.
Having same problem on Philips: ambilight ok, sound ok, image ok if lit with flashlight. For this one I don't know the issue yet but suspect power supply. Well, unlikely the fuse as I had this issue last week then TV came to life again few hours later, ’til tonight…
I had similar issue before on Panasonic TV going black and the more you wait the more it stays on, then red LED blinks.  For this one, it was one backlight LED which started to go away. Cold TV, contact is good enough. When hot, this white LED goes off, then I guess a probe shuts down the whole backlight and warn with red LED blink. Re-soldering this single LED saved the TV.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@lcld sound slike failed backlight array. First it's a Philips, and they are having lots of issues with that. Of course, we will need to know the exact model. You can and should measure the DC voltage on the LCD backlight connector on the power board. It is VDC so use your meter accordingly and start high and work dow i.e. 300V then move your meter down. Let us know that voltages you get. Of course you can get an inexpensive backlight tester (~USD$25) at places like Amazon and then you will know for sure.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
lcld 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 17
