跳转到主内容
加入维修社区 - 创建账户
Epson 生产的一款多功能打印机。
Not printing. Has ink?
Not printing pages. Occasional yellow lines. Inks are all fine. ????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Perform a Full Power Cycle – Before we go any further, make sure you perform a complete power cycle on your printer. This is a fancy way of saying turn it off and on again. Completely shut down the printer, remove the power source and disconnect all cables. Wait a few moments, then fire it back up and see if your problem is solved.
Print a Test Page – A test page is a simple way to determine your printer’s performance and see if any black ink makes it onto the page. You should be able to find this option on your printer’s display screen. It may have a different name, such as “Quality Diagnostic Report”.
Check Cartridge Levels – Check the estimated ink levels of your printer cartridges and replace any low or empty ones.
Check Printer is Set Up Correctly – Consult the user manual and ensure the printer setup is correct.
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
If you do not use an inkjet constantly, the ink will dry on the heads and it won't print. Sometimes you can fix this buy doing multiple cleaning exercises. Otherwise, you need to replace the cartridges if the heads are on the cartridge or remove all the cartridges and CAREFULLY clean the heads with ISO Alcohol.
这个答案有帮助吗?
得分 0
添加一条评论
la impresora no prende
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Barbara Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 407
