How to fix reboot?
Suddenly reboot continuously , network not working 😞 what's the solution for this ? When enter the camera app the mobile is restart , set high volume the mobile also restart .
Hi!
Usually in cases like this you may have to flash new software on the your phone as there may be software problems causing the phone to restart. You may want to try to restore your phone using the Windows Device Recovery Tool.
Please be aware that this will almost certainly erase all the data on your phone. So backup any important information BEFORE you connect your phone to the program.
Please note: You will need a set of Torx screwdrivers and opening tools to remove screws and parts, both of which are readily available on the iFixit store and on Amazon.
If neither of those fixes do not help you then your phone may have a fault with the motherboard. At that point I'd recommend contacting a professional to have the specific program diagnosed.
这个答案有帮助吗?
You can download the Windows Device Recovery Tool from Microsoft using the link below:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 354
