跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Vertical Lines appears on screen without the device being damaged
Hello guys! My nintendo switch lite screen suddenly appears to have a vertical lines on my left side screen. The lines appeared suddenly when i was running game. Ive never dropped the device and it never fell before. Any idea how to fix it? Or is it just a software glitch?
Update (10/25/2022)
Here
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Can you attach a picture of the screen please?
完成的
@guardian10 Can i upload the photo here via iphone? Sorry i am a first timer here :(
完成的
I have an Nintendo switch wish the screen is kind of blurry with lines
完成的
I have switch lite and same problem with me without drop or anything screen will blur and verticle lines appear, this is manufacturing defect from nintendo, need to submit petition in court, they ignoring this problem.
完成的
添加一条评论
3个答案
最有帮助的答案
You're definitely seeing a problem with the LCD; it's really hard to say whether it's a problem with the flex cable where it is attached to the glass, or if it's a crack or defect in the LCD itself, but either way the effect is the same; you'll have to replace the entire LCD to fix it.
There is a very small chance it could have something to do with the connector where the display plugs into the motherboard, and it's worth checking, but I'm fairly confident you're going to have to replace the LCD. Here in the US, iFixit sells a replacement for $55 USD, which isn't cheap, but it's less than the cost of a whole new Switch.
Nintendo Switch Lite LCD: Replacement Display Panel
The job of replacing the LCD is, unfortunately, one of the more difficult repairs possible on a Switch. To get to the screen, you literally have to remove every other part inside the case, so it's a fairly big job as far as Switch repairs go. It is, on the other hand, straight-forward and if you can use a screwdriver and tweezers anyone can successfully replace a screen if you follow the guide.
Nintendo Switch Lite Screen Replacement - iFixit Repair Guide
If you want to try to check the connector first before committing to replacing the screen, follow the Game Card Reader / Headphone Jack replacement guide to access that connector.
Nintendo Switch Lite Game Card Reader and Headphone Jack Replacement - iFixit Repair Guide
Once you get to the last step, you can then open the retaining tab on the LCD cable and pull it out to see if you can find any signs of damage or corrosion. Use a magnifying glass and a bright light to check the motherboard connector, and both sides of as much of the cable as you can see. Clean the pins on the cable with 90% or higher isopropyl alcohol (don't use the 70% stuff we all have around the house) and reinsert the flex cable then lock it down. See steps 26 and 27 on the Screen Replacement guide for instructions. When reinserting the cable, make sure the two little ears on either side are both butted up against the motherboard connector. If you don't get it in all the way, you'll have more problems with the screen and may have to open it up again to resecure the connector.
Once you're done with that, reassemble everything and see if there's any difference. If not, you'll have to make the choice as to whether you can live with the display as is or if you want to tackle a somewhat difficult repair and incur the cost of a replacement screen.
Either way, I wish you luck. Let us know how it goes.
Replace an LCD screen compatible with the Nintendo Switch Lite handheld gaming device.图片
产品
$54.99
Nintendo Switch Lite 游戏卡读卡器和耳机插孔图片
指南
任天堂游戏卡读卡器和耳机插孔
难度:
中等
20 minutes - 1 hour
Nintendo Switch Lite LCD 显示屏图片
指南
Nintendo Switch Lite LCD 显示屏更换
难度:
中等
45 minutes - 2 hours
这个答案有帮助吗?
得分 4
2条评论:
Thanks buddy. I appreciate your advice and thanks for your help regarding this issue :)
完成的
I know this is an old thread but thanks for your advice! I've had the same issue happen to me but the whole screen had vertical lines, I followed your advice and replaced the lcd and its as good as new. Thanks again :)
完成的
添加一条评论
I have this problem too, and idk why i got this vertical lines on my switch lite. It started 4 days ago. When i turned it on and i saw it on the left side of the screen.
这个答案有帮助吗?
得分 1
1条评论:
Did you fix it somehow, if you did please tell me how u fixed it
完成的
添加一条评论
There was lies on the right side of my Nintendo and it fix itself so we don’t have to pay for it to be fixed
Update (04/22/24)
And I hit it with a ps5 controller not hard when it was playing fortnite and we had school today so I was on a game and my dad said to get off but I was in a game
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iamadihakimi 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 78
过去 30 天: 289
总计 17,126
