Hi can anyone help me with the size of screw I would need to replace
Hi can anyone help me with screw size as mine have come out it’s the part that holds the cable in place
katrinarobinson82 that is perfect. I would take the headset to my local hardware store. Mom and Pop hardware is still the best since the larger warehouse style hardware stores do not quite have the personal touch. Show them what you are looking for. Those will most likely by small metric threads. You can try the screws right there and get the size you need. The other places I would try are Jewellers, watchmakers and local RC and electronic clubs. Those people never throw anything out and you'll be surprised what you'll find.
Since those look like inserts, you can measure the hole with a pair of calipers to determine which size you will need. Local machine shops and technical colleges can help you with that as well.
这个答案有帮助吗?
Thank you I’ve tried several different shops but still not managed to find out the size
This headset is not a valve index headset id suggest reposting it in the Vive headset section you may have better luck there. I suspect this headset is the HTC Vive Pro, but I am not sure you would know better than me
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 131
katrinarobinson82 what screw? Post a picture so we can try and help better 在已经存在的问题里加入图片
由 oldturkey03 完成的
I’ve attached pictures
由 katrinarobinson82 完成的
