跳转到主内容
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
35 个问题 查看全部
Battery seems to have crapped out. Need to retrieve data from hard dri
Hey everyone. I have a Microsoft Surface Pro 6. It has a 256 GB HDD hard drive. For some reason the battery died and I have not been able to back up the computer does anyone know how I can recover the data from the hard drive? It's hard drive is NOT removable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@nattychamps it’s my understanding that your Surface Pro 6 does not have a HDD. It uses a soldered 256 GB ssd. Since it is soldered the answer of removing it and to do a recovery of the files, would be no. Now it might be possible to desolder it and possibly rig it to an external case. Not for the faint hearted and definitely not plug-and-play
这个答案有帮助吗?
得分 1
2条评论:
Is this another case where you've got a device that's not capable of running on external power alone, even with a dead battery? I really hate it when they do that.
If the problem is just the battery, then it seems like the easiest way to get your data back is to replace the battery. Although to be honest after reading the battery replacement guide, it's a b*tch of a job.
完成的
@dadibrokeit
Doing regular backups doesn't seem to be in fashion anymore. There's even free storage online, if you don't want to buy an external drive. You can back up a maximum of 5 GB of files in OneDrive for free, or up to 1 TB with a Microsoft 365 subscription. Set to periodic auto backup and no worries about hardware failures, unless you're concerned about MS accessing your data that is.
完成的
添加一条评论
添加你的答案
Wes Ivester 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 92
