跳转到主内容
Lenovo laptop released in 2019, model number 81LW000QSB.
Why is my keyboard getting hot
Lenovo IdeaPad L340-15IRH GAMING laptop and when i play games the keyboard gets hot. Plus the battery drains to fast can you please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
First run some diagnostic software like Speccy or HWMonitor to check if the temps are higher than they should, for reference take a look at the values showed in this full review of your laptop ("Temperature" paragraph). In this case, aside from keeping your laptop on a solid, flat surface while it's operating, here are some possible solutions to the laptop's oveheating problems:
  • check if the fans are working properly, basically you should feel with your hand they're effectively blowing hot air out of the chassis, a software like HWMonitor or speedfan will give you real-time info on the system's fan speeds
  • if the fans are constantly spinning without issue and temps are still too high, air vents could be clogged: assuming that the warranty period has expired, I suggest you turn off, open up the laptop (with all due precautions) and remove all the dust from the inside (refrain from using a vacuum cleaner or air can, use instead an anti-static brush or a dust blower) , especially the air vents (and filters) and fans; while you're at it, replace the thermal paste if needed.
Other tricks that will help you keep your system cooler are:
  • adding a cooling pad to get better airflow
  • tweak the performance settings from the Power Options menu
  • as suggested by @komota, anti-spam/virus/malware software will help you prevent CPU-intensive unwanted apps to run on your PC
  • any missing or worn rubber spacers under the laptop should be replaced
Finally, to get info on your battery's health on Windows, type the "powercfg /batteryreport" command, then simply open the newly created report (it's in your home folder). For more information, check out this article
Hope this helps
Cheers
这个答案有帮助吗?
得分 2
添加一条评论
I would say problem is that something is using PC a lot. I would check malware or other software to see what is using pc resources a lot and kill that process, then i will not make heat and then it should work bit faster
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dawn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 677
