跳转到主内容
No longer powers on.
MegaBlast won’t turn on.
This speaker is about a year old, seen moderate use and has never exposed to water, extreme temperatures or shock.
I have tried:
  • Charging the speaker using various cables and adapters over a couple days.
  • Charging via the PowerUp dock for a couple hrs- dock indicates charge complete solid light (battery is fully charged‽)
  • Did a hard reset
I’m out of ideas… If anyone knows of a teardown or repair guide for this device they can link me, I guess my next troubleshooting steps are pull ‘er apart and check components and solder joints. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Speaker needs disabled, and battery replaced
这个答案有帮助吗?
得分 0
添加一条评论
@rachelembleton replace the battery and use that for further troubleshooting if necessary. Right now it sounds like a bad battery. It may accept a charge but does not hold a charge. With a new battery you will at least have a known-well starting point for further troubleshooting.
There are no iFixit guides for the battery replacement yet. You will have to peacemeal it together by using something like this as well as this video
Also, if you need any help, or if you are stuck somewhere, you can always post pictures with your question so we can try and help you further with this.
在已经存在的问题里加入图片
Take lots of pictures and once you have your battery successfully changed, use this guide https://www.ifixit.com/Guide/new to create a guide. The iFixit community will appreciate it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rachel Embleton 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 94
总计 866
