跳转到主内容
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
21 个问题 查看全部
qc25 headphone wire jack does not connect
Hi, I have a qc25 headphones and yesterday my audio cable no longer connects to the earcup and stay connected, I notice the small piece that it is supposed to connect to, is lose and seemed to have been "pushed" out of it's plastic holder.
Is there any way to fix this?
thanks
amit
Hi, the part that connects to the end of the audio cable seems to have been disconnected from the plastic piece that holds it together to the ear cup, allowing the male connector to the female connector. I can hear it rattling around, but I can not take everything apart to reach it. Seems to need a special tool to connect it while screwing the plastic piece.
see images; sorry it is very hard to take a picture of it, as it is internal and hard to get the light in there.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@amitbarkan73 if you are referring to the headphone jack then it is time to take your headphones apart to investigate what has come off. Use these guides to work on your Bose. Bose QuietComfort 25
Post plenty of pictures of what you encounter with your QUESTION so we can see what you see. I've replaced my jack with a permanently connected audio cable. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
1条评论:
updated images and explanation. thank you
完成的
添加一条评论
添加你的答案
AMIT BARKAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 408
