跳转到主内容
Electric trimmer for grass edges and confined spaces. Also known as a Strimmer.
1 个问题 查看全部
Motor slows down and stops
The motor gets hot and stops in a few seconds. The commutator has burn marks and beads of metal(?) alongside it. I have measured the resistances between each adjacent segment on the commutator, they are all between 3.5 and 4 ohm each. The brushes seem to be OK. Does the insulation break down? I tried cleaning it up but it goes bad the same way when turned on for a few seconds.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@alanport yes you will need a new one. the wires are insulation coated. It gets hot and melts and shortens out. There are places that rewind those but the cost will most likely exceed the cost of a new motor
这个答案有帮助吗?
得分 3
1条评论:
Thanks, no surprise really.
完成的
添加一条评论
添加你的答案
Alan Thurbon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 33
