跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note 9 是小米于 2020 年 4 月发布的一款中端智能手机。它配备 6.53 英寸 IPS LCD 显示屏、4800 万像素主摄像头、后置指纹传感器和 5020 mAh 电池,运行 MediaTek Helio G85 处理器。
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
完成的
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
完成的
non of the above works i have tried power and volume+ button but it is not going on that
完成的
添加一条评论
3个答案
最有帮助的答案
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
这个答案有帮助吗?
得分 1
添加一条评论
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
这个答案有帮助吗?
得分 0
1条评论:
I've set it back to Factory mode multiple times, so this is not working.
完成的
添加一条评论
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Kastner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 1,435
