跳转到主内容
加入维修社区 - 创建账户
Replacing Ceiling Fan That Has Separate Light Fixture
I have a Hampton Bay fan on my porch, as well as a separate light fixture. They are both controlled by a Hampton Bay remote, and are both wired to the same wall switch.
My light works well, but the fan's rotation is way too slow and a new capacitor didn't fix it. The fan is old and not the style I want, so I'm prepared to replace it.
Is there anything I need to consider about replacing the fan, knowing that I still want the light to be controlled via remote? I'm worried that if I replace the current fan with a new one, I won't be able to control the light anymore.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi Kenny,
I would think your best shot at this would be to buy a Hampton Bay brand fan as a replacement. There are two ways I see this working for you.
  1. The new fan has DIP switches that can be set to match the frequency of the old remote, which you could hopefully keep using.
  2. You could keep the existing wireless receiver and install the new fan with it, in which case you can be confident the new fan will still work with the remote you already have. In this case you could probably get away with buying any brand of fan you want.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much! I’ll give that a try.
完成的
添加一条评论
Mi ventilador no funciona con el control
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenny Coleman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 593
