跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Lighting connector replace problem
I am replacing my lightning connector assembly but I cannot remember where thr two antennas connect on the logic board (or does it not matter)
Does the one from the speaker go on the lower point or the top point on the logic board
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
The antenna connection are both at the bottom of the logicboard
If you follow this guide
iPhone 7 主板更换
On step 33 it shows you where they go
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
4条评论:
Thanks but the image in step 33 is still not clear which goes where. Is the cable from the speaker the lower one or the higher one
完成的
@baker-paul16
From what iFixits video shows i think the bottom one is for WiFi and the top is for the the lightning connector assembly
You might also be able to tell from the shape that the cables are bent:-)
完成的
I agree but be good if anyone can confirm
完成的
@baker-paul16
Here’s a video for confirmation
https://m.youtube.com/watch?v=GWYV4beNLa...
The longer of the two antennas goes at the top and the smaller one goes at the bottom:-)
完成的
添加一条评论
添加你的答案
baker-paul16 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 62
