跳转到主内容
加入维修社区 - 创建账户
Samsung RF4287HA** 冰箱的维修及相关信息——这是一款 2010 年推出的底部冷冻柜机型,配有抽屉和对开门,并设有用于控制凝露的防凝露加热器开关。本页面涵盖型号 RF4287HA** 的相关信息。
Fridge not getting to set temperature
Hi, I have a Samsung model rf4287hsrs. I recently noticed the fridge temp is not getting to the set point. I had it set to 34 degrees and the temp sensor built into the fridge says 34 degrees. However when I check the temp of milk and food from the fridge they are at 40 degrees. So I put temp sensor on each shelf. Top shelf is 44 deg, middle is 41 and Bottom is 38. Could the temp sensor developed a bias?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
The sensor could go faulty and give incorrect readings.
Try the self diagnostic during normal operation and check if it shows that the sensor is OK or not.
No doubt it will so the next thing is to actually test it yourself.
Here's the troubleshooting page which shows how to test it and here's the voltage/resistance chart but to determine if it is the sensor or perhaps the control pcb you may have to test the sensor in isolation i.e. disconnect it from the control board and then test it using an Ohmmeter.
The sensor is a 502AT type so check if it measures the correct resistance value at what the temperature is when you test it. You may need to have a thermometer on hand.
If it is faulty use this link to find your exact model and then search for "sensor" to hopefully find out exactly where it is located in the refrigerator. Then use the manufacturer's part number for the sensor to find suppliers that suit you best.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joseph Schneider 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,701
