跳转到主内容
加入维修社区 - 创建账户
2021 年 10 月发布的 14 英寸 MacBook Pro 的维修指南和拆解信息,搭载 Apple 设计的 M1 Pro 和 M1 Max SoC。型号 A2442。
Messed up removing flex cable
I think I accidentally stripped off one of the metal connections when removing the flex cable on the logic board. Have I completely screwed this up?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi
Thankfully it hasn’t completely messed up the board because all but one of the pads looks ok
The other pin(highlighted in the photo) might have been ripped
The connector that has fallen off is for battery data,but in order to fix this you will need to solder it back on ,as for the pad we think is ripped :do you have the connector the fell off?
If so can you upload some photos of the side that faces the Board so we can see if the pad went with it
If you don’t have good microsoldering experience you might not want to attempt this repair and It would be better to have it taken to a professional as it may require replacing the pad that fell off and reattaching the connector so that it’s secure
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 4
2条评论:
Yep certainly not experienced enough, I’ll be taking this to get repaired thank you so much.
由完成的
@Chris Grant (Lifeoverflow)
You’re most welcome!
Please let me know if there is anything else:-)
由完成的
添加一条评论
添加你的答案
Chris Grant (Lifeoverflow) 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 21
总计 526
