跳转到主内容
New battery issue - MagSafe switching light from green to amber
Hi guys,
I get new battery from NinjaBatt (not sure if it's good brand or not but according to Amazon have a good result). So I installed new battery, connect to MagSafe and turn on. Reseted SMC and NVRAM. Then normal start BUT, MBP is too slow (Blackmagic Disk Speed Test show write 5MB/s !!!) and the light on MagSafe changing from green to amber (+/- 6 seconds green and 11 seconds amber). If I push side button for battery I get just first light flashing. In macOS I have 0%.
I have two MBP 2011 - identical same CPU, same RAM so I put the battery in to the second one but same result.
I also tried three different MagSafe chargers - two genuine Apple, one third party - same result.
So look to me like the battery is bad ? Or you guys have any more ideas ? Thanks a lot.
Coconut battery - it’s switching between pictures below.
Update after 14 hours on charger
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
@danj Done, it’s switching between two screens.
完成的
Make sure your Coconut Battery version is the latest and tell us if there is a difference in the report you get.
完成的
@mayer last version from webpage.
完成的
添加一条评论
2个答案
已选择的解决方案
Sadly this is a bad battery ;-{
At this point you'll need to get your money back and try another source
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Sometimes a completely drained battery will respond to an overnight charging session.
这个答案有帮助吗?
得分 1
4条评论:
I will leave it over day, I want have it under control, but thanks for advice
完成的
Update - after 14 hours on charger.
完成的
I'm no battery expert, but sure sounds like a bad battery to me.
Have you contacted the vendor and asked them about this behavior?
完成的
@dadibrokeit I did but still no answer.
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 87
