跳转到主内容
加入维修社区 - 创建账户
Logitech M310 无线鼠标的维修与拆解信息。该鼠标可单独购买,或作为 MK540 套装的一部分。可通过型号 M-R0014 进行识别。
Right clicker does not work occasionally.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check Hardware Issue. If you encounter the issue mouse right-click not working, you can plug your mouse into a different USB port first and check whether the issue of right click not working is solved. Then if the above way does not work, you can also change another mouse and plug it into your computer.
Regards,
Will
这个答案有帮助吗?
得分 1
3条评论:
I fixed it, just needed a clean and some tape.
由完成的
Worst case scenario to consider,
You've clicked in excess of 100 million times and the switch has fatigue failed. This is expected after 3-4 years of daily use. I bought a bag of omron 50M rated switches for all of my mice.
由完成的
@normalladd Thanks, for the tip!
由完成的
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 1,901
