Logitech MX Master 3S get wet!
Logitech MX Master 3S get wet and stop working. I have disassembled few times, used electronic cleaner for all boards but no success. Charging light always red regardless how long I am charging. What to do?
Igor Vysoc you did not tell us if you removed those boards. If you did, post some pictures of those with your QUESTION. 在已经存在的问题里加入图片
It is always best to remove and to properly clean everything with some high grade isopropyl alcohol. For a proper cleaning, use this guide. 修复iPhone 的进水故障 It was written for a Apple iPhone 3G but it is still pertinent to your mouse as well. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once properly cleaned, REPLACE THE BATTERY and reassemble to re-evaluate.
这个答案有帮助吗?
Hi everyone I made the same mistake. My left button got stuck and I didn’t want to open the mouse and I tried with contact spray to spray in the holes of the left click. But then the mouse stopped working. The red light is blinking, then I open the mouse there is no visible issue. I disconnect the battery tried to connect directly with cable but still got the red light and no option to connect with any device.
这个答案有帮助吗?
I have the same and exact scenario as you, my left button out of nowhere just stopped working. I tried to clean with a contact cleaner, when I switched it on again - then the red light is blinking. This is a very frustrating issue, and it's seems like the issue is repeatable with others. This must be something to do with there firmware and this is not a hardware issue - maybe, just maybe, Logitech is doing this on purpose.
Have you tried to fix it? I love this mouse, if it doesn't work anymore I have no choice but to buy again.
i got the same issue with the same rational, any solution got working with you
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 43
总计 2,765
2条评论
Thanks for suggestions. I did everything: remove all boards completely, cleaned all visible spots that possibly from water. But I have used CRC brand QD Electronic Cleaner. My concern about lithium battery. Its label says 4.2V, but can be charged up to 4.1V only.
Do I need to replace it? Again, regardless how long I am charging - red light (mouse indicator) always present, not green.
由 Igor Vysoc 完成的
Igor Vysoc that voltage is ok. But it is not enough to test the voltage to prove that the battery is okay. If it got wet etc, I would replace it as well.
由 oldturkey03 完成的
