跳转到主内容
加入维修社区 - 创建账户
De'Longhi BCO430 咖啡中心是一款集泵压式意式浓缩咖啡机与 10 杯滴滤式咖啡机于一体的机器,配有打奶泡棒,采用银黑配色。
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Did these images come ok?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
8条评论:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
完成的
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
在已经存在的问题里加入图片
完成的
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
完成的
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
完成的
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
完成的
显示更多的3条评论
添加一条评论
These coffee makers often are similar. Compare to 拆卸 Saeco Magic Capuccino SIN017 锅炉 and Starbucks barista , perhaps it helps. Good luck!
Starbucks Barista图片
指南
Starbucks Barista 拆解
难度:
中等
Saeco Magic Capuccino SIN017 拆卸锅炉图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
Pics attached - this is how far I could get
Update (10/08/2022)
这个答案有帮助吗?
得分 0
添加一条评论
Update (10/08/2022)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
liluet_hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 466
