跳转到主内容
华为在2018年三月发布的旗舰手机,型号为CLT-L29
Why are there vertical black lines after an LCD repair?
Hello, I have replaced the LCD screen for my Huawei p20 pro. The phone turns on fine but there is a thick black vertical line running down the display screen.
I have checked the connection which is secure and hope I haven't damaged the flex cable as I was super careful! Is there anything else I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Farhan Shahid, if you checked your connector ends (both and those look ok, double check the cable for tears etc. If all that checks out ok, contact the seller and replace the screen. It's possible that you have a bad screen. Happens more often than we hear about.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Farhan Shahid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 359
