跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
Samsung LN32B530P7F display flashing on/off
Samsung LN32B530P7F was left plugged directly in the wall by guests. Returned to find the tv responsive to input but nothing on display. Ordered and replaced the power board (entirely scorched) BN44-00261A. New board listed as compatible with BN44-00260/1 A/B/C.
After replacement, TV display comes on and all functions appear normal (renders HDMI signal, plays audio, responds to input/channel/volume/etc), but flashes off and on 3 times before the display shuts off entirely. The TV is still on and responsive while the display is off, and remembers all config changes.
Following other advice, power drained the unit (unplug, hold power, replug), and it automatically turned itself on, the power LED blinked twice before the screen came on doing the same thing again (on/off 3 times). The suggestion there is the main board.
Noticed that not all HDMI ports worked ok, so suspect lightning damage there too. Ordered a replacement BN41-01181A. Fingers crossed.
Anyone else observed this kind of behaviour? Was it limited to the main and power boards?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@icantdothatdave looks like the main board had some issues with the processor or the heatsink was applied wrong. See how it is offset? That would lead me to believe something not quite right on that (as well as the HDMI issue) I believe it is the prudent thing to change the main board. Since we do not know what damaged it, it could still be something else but you are doing right by changing one at a time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
