back light flashing about every 5 seconds
I have similar problem with back light flashing about every 5 seconds. When I disconnect the cable to the main board the back light flickers very quickly.
@jmp1 when you separate the mainboard from the power board, the backlight should come on continuously. What you are describing sounds very much like a failed backlight strip. If you give us your complete model number we can probably guide you to the right replacements. Changing those is not a terribly complicated job, just tedious and a bit of a PITA depending on the size of the panel
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 17
Hi John,
What's the model number of your TV? That'll help the members here in diagnosing your problem.
由 Jerry Wheeler 完成的
