跳转到主内容
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
202 个问题 查看全部
Mac Pro 4.1 flashed to 5.1
Hi guys, (@mayer)
I am wondering if I flash MP 4.1 to 5.1 what other "modifications" are need to get "full MP 5.1" ?
Is software/hardware support same for flashed 4.1 and 5.1 or there are any differences ?
Can I modified CPU heatsink from 4.1 so I will be able to use normal CPU and no de-lidded ?
Can I use normal CPU (no de-lidded) in MP 4.1 if I use water cooling ?
Anyone have any experiences with MP water cooling ?
Thanks a lot guys.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Watch this and then see if you have unanswered question:
https://www.youtube.com/watch?v=VrbnfYgg...
这个答案有帮助吗?
得分 3
5条评论:
@mayer thanks a lot for the video :)
but he using "normal CPU" so are de-lidded CPU's only in MP 4.1 dual CPU ?
also can't read the spec on RAM's but I know that MP 5.1 support 1333MHz why he using 1066MHz ? (will MP 4.1 flashed to 5.1 support 1333MHz ?)
Thanks
完成的
I remember that I has to use delided CPUs on the 2009 2.9 dual machines. I'm still using the 1066MHz RAM in both a 2009 & a 2010.
Here's a vid on the deluding:
https://www.youtube.com/watch?v=Et29f4uT...
完成的
As a note, I used DodDudes method to upgrade to High Sierra and that PCIe SSD crashes about 3-4 times a day in both the 2009 & 2010 Mac Pros.
完成的
@mayer isn't 2010 officially supported by High Sierra or you have to do this because PCIe SSD (mean DodDudes) ?
Well this is why I am so confused about de-lidded CPU's but if I check price for 2x de-lidded X5690 and dual CPU try for 5.1 it's almost same price :D
and what about SW/HW differences /support ? is there any for 5.1 and 4.1 flashed to 5.1 ?
完成的
I did the DosDude upgrade on my 2009 2x 2.93. It was crashing, so moved the PCIe card with the SSD drive to the 2010 and it keeps crashing. Need to backup data, reformat drive and do the install on the 2010. BTW the 2009 processor board will not move to the 2010.
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 178
