跳转到主内容
My phone is not charging
My s10e is not charging. Each time I I plug it in it shows a notification saying that the cable is not recognised. I have tried rebooting the device and using a different cable and power source. Should I replace the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Ibrahim Hanif make sure that you do have a good cable and you could try an original. If that does not work you will have to check the power port. Clean it with a couple of drops of isopropyl Alcohol and some puffs of compressed air or equivalent. If that does not change anything your next step would be to replace the charging board.
A bad battery would not give you that type of error message. If you take your phone apart its always a good idea to change it anyway.
这个答案有帮助吗?
得分 1
添加一条评论
Probably damaged charge port,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ibrahim Hanif 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 265
