跳转到主内容
加入维修社区 - 创建账户
DeLonghi ESAM 咖啡机有不同的系列。在机器底部通常贴有标有 ESAM 3xxx、ESAM 5xxx 或 ESAM 6xxx 型号的标签。
Delonghi Caffe Corso Flashing Water Tank Error
Hello, my Caffe Corso worked fine until a few weeks ago when it stopped making coffee. I took the entire thing apart water pipes, pump, valve etc. and found the primary issue - a huge rock of limescale clogging one of the smaller pipes - and removed it. Water now flows, however, only for circa 10 seconds and suddenly it cuts out with the water tank light flashing. I can try again and it will work but again, only for circa 10 seconds. Does anyone have any ideas aside from the usual one of turning the steam nob because this only works for 10 seconds too. For the same reason, it cannot be properly descaled, although I've manually ran this. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Did this tips helped out...I also have this problem
完成的
添加一条评论
1个答案
Have a look for the flowmeter. There is a guide for the ECAM series, the flowmeter for ESAM is the same.
DeLonghi ECAM 系列流量计更换/检修
(In German, use Google translate)
The test mode could bei helpful:
DeLonghi ESAM xxxx - 测试模式
And: there is a "finger" on the rear side of the drip tray. If it is broken, the machine does not "feel" the closed tray.
2nd and: worst case: a clogged heater...
DeLonghi ESAM Family图片
指南
难度:
中等
DeLonghi ECAM Series 流量计更换/检修图片
指南
难度:
中等
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lewis Bateman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 1,713
