Excess water from drain pump hose after each load
I have an LG WM3050. I have to drain the water from the drain pump hose after every load, and it drains at least 2 cups. If I don't drain it, water ends up on floor under machine on next load. I took the washer apart, checked all the hoses, and replaced the drain pump with a new one. Still happening. There is no water left in the tub when load is finished, and clothes aren't too wet, so I know the water is clearing the tub. Anyone know what could be causing this problem?
2条评论
Did you ever find a solution to this problem? I have exactly the same issue.
由 lindyfairbrother@hotmail.com 完成的
@lindyfairb75751 Unfortunately, no. I replaced the pressure sensor and blew into the hose to clear anything out. Still having the same issue. Did you find any other solution?
由 Tammy Markwell 完成的
