跳转到主内容
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 个问题 查看全部
问题已关闭
iPod nano 6th generation turn on/off button stucks
ipod nano 6th generation turn on/off button stucks
how do i fix that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
About to try this guy's guide/solution myself. I'll let you know how it goes.
http://www.rbarrios.com/projects/NANO6BU...
这个答案有帮助吗?
得分 2
2条评论:
+1 nice link
完成的
+seen this link on another question and everyone solved the problem.
完成的
添加一条评论
This Guide will assist you in dis-assembly.
Check to see if something has been damaged or perhaps something is causing the switch to stick - liquid ingress etc.
这个答案有帮助吗?
得分 1
添加一条评论
More than likely the dome switch under the button is just worn. A simple power flex cable repair will fix it.
这个答案有帮助吗?
得分 0
添加一条评论
This is a very common issue for the 6th gen. It is due to wear (pushing them) on the button. Luckily it can be fixed.
ipod nano on/off button repair
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,452
