iPod nano 6th generation turn on/off button stucks
ipod nano 6th generation turn on/off button stucks
how do i fix that?
About to try this guy's guide/solution myself. I'll let you know how it goes.
这个答案有帮助吗?
+1 nice link
+seen this link on another question and everyone solved the problem.
This Guide will assist you in dis-assembly.
Check to see if something has been damaged or perhaps something is causing the switch to stick - liquid ingress etc.
这个答案有帮助吗?
More than likely the dome switch under the button is just worn. A simple power flex cable repair will fix it.
这个答案有帮助吗?
This is a very common issue for the 6th gen. It is due to wear (pushing them) on the button. Luckily it can be fixed.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,452
