跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
Thin black line on left of screen
I have 65 in Samsung curve that did not have power
I changed the main board and now have power but also now have a thin black line coming down the left side of the screen. I was careful with all connections and believe they are all properly and securely back in place. Any help with this would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@jodyjames we really would need to see what this all looks like. Post some good images by editing your QUESTION and follow this guide. 在已经存在的问题里加入图片
What you are describing sounds like a TAB error. The bonding of the very thin ribbon cable entering the LCD panel may have come off, corroded or broke. You will have to remove the back cover and make out the TAB, then apply some pressure to the thin ribbon cable at exactly the point where the line appears. If that changes the line then it is a TAB error. Most of those cannot be repaired but require replacement. Sometimes the application of a piece of strong tape applies enough pressure to create the connection but this may only be temporary.
The attached images are just an example of what to look for.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jody 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 29
