跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A20 于 2019 年 4 月发布。它拥有一块 6.4 英寸的屏幕,背面配有双摄像头。
Constant overheating when idle
My Samsung Galaxy A20 has had constant overheating issues recently. It will normally be idling or undergoing light use before closing all apps and then shutting off due to overheating. It happens multiple times per day and will occasionally have no issues some days. The thing is that sometimes the phone is genuinely cold prior to shutting down due to overheating. The only way to turn the phone back on is by entering recovery mode and booting the device from there, and then it will be fine for a few hours before encountering overheating issues again. I have a feeling that it may be an issue with the thermal sensor but I am not sure. Does anyone have any suggestions or have encountered this issue before?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you try to reset your phone? Any hidden app or malware running in the background might be possible.
由完成的
The issues continue to arise in safe mode and I have no plans of performing a factory reset on the device. Others who have had similar/identical issues that have performed a factory reset continue to have overheating errors. I ended up removing the thermal sensor and that solved my issues. Thank you for your comment.
由完成的
添加一条评论
1个答案
已选择的解决方案
Ok, so I ended up following the advice found in this thread: A50 won't charage or turn on - Overheating icon
The issues I had were identical to this person and I performed the fix by removing the three small PCB components. Additionally, my ability to charge the phone had not been impacted. However, you can easily find a replacement charging port PCB on Amazon for cheap.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Larsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 762
