跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Pro 8 维修指南,发布于 2021 年 9 月 22 日。
Screen replacement for Microsoft Surface Pro 8
Where can I find a genuine screen part for surface pro 8?
My screen is cracked and I can't find any reliable supplier. I can't find a replacement guide for the device as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Your best bet would be to try to find a replacement screen secondhand. There is a supplier on eBay that I will link here. The Surface 8 Pro does not have a guide yet, but from what I can find the screen replacement guide for the Surface Pro X is supposed to have the same process. I also highly recommend you document your repair process and upload it here for others who may have a similar issue.
这个答案有帮助吗?
得分 5
3条评论:
Thanks for help!
Unfortunately it's out of stock in the link above and I can't find it anywhere.
I hope ifixit provide it soon.
完成的
I also wonder if Surface Pro X screen is compataible with Surface Pro 8?
完成的
@itohamy It wouldn't surprise me if they shared compatible parts. However, if they are compatible then it's not documented on the parts page. If push comes to shove, you could try and find a junked Surface Pro 8 and use it for spare parts. I'm also wondering if there is a way you can contact Microsofts support and just order the part from them directly. They are partnered with iFixit, so it could be a possibility that you can do it that way.
完成的
添加一条评论
Ifixit has replacement screen for the Surface Pro 8 now: Microsoft Surface Pro 8 Screens
这个答案有帮助吗?
得分 1
1条评论:
It seems like it changes the link to text when posting: www.ifixit.com/Parts/Microsoft_Surface_Pro_8/Screens
完成的
添加一条评论
添加你的答案
Ahmed El Tohamy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 8,646
