跳转到主内容
加入维修社区 - 创建账户
搭载 Ayre Acoustics 电路设计的便携式媒体播放器。支持 Micro SD 内存扩展,电池不可更换。
Sticky Pono player fix?
Sticky rubberized surface PONO player . Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
If your !!%@$ player is sticky you should be more careful when ^$$&@@*$@*@.
由完成的
添加一条评论
1个答案
已选择的解决方案
You will need to get alcohol pads or a bottle of Isopropyl (Rubbing) alcohol and paper towels.
If using alcohol pads:
  • Use the alcohol pads to rub the sticky rubber coaating off the device, revealing the plastic underneath.
If using paper towels:
  • Get a paper towel damp but not wet with Isopropyl alcohol
  • Rub the paper towel on the sticky rubber coating. It should slowly come off
  • Use a separate paper towel ro dry the alcohol off
这个答案有帮助吗?
得分 3
4条评论:
After your suggestion, I did try this again. It just becomes more and more sticky. It doesn't appear to work, even after persistent scrubbing. Tried the baking soda technique suggested elsewhere, to no avail. Also tried car plastic trim treatment. Someone suggested nail polish remover.Bit scared to use that, but this device is a gummy mess now...
由完成的
I finally took off the rear cover, to safely work on the back. Vigorous rubbing with rubbing alcohol, hot water with soap , vinegar..and eventually using a guitar pick I scraped most of the sticky material off. I can't really do that to the front safely. Might spray on clear sealant (?)
由完成的
Thank you for the advice. After trying all the methods, yours worked the best.
It took me about an hour, but managed to clean the front off without damage using a microfiber cloth, rubbing alcohol and a guitar pick.
由完成的
@volkers Glad I could help. I would appreciate if you could mark my answer as the solution by selecting Options>Mark Answer as solution where my answer is.
由完成的
添加一条评论
添加你的答案
volkers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 351
