跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad 3 15IIL05 是一款定位中端的笔记本电脑,专为常规计算任务设计。
Will Not Power up
My laptop was running fine and had nothing happened to it.
Just Turned it off one-day and it would not turn back on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hi @malice9182 ,
Does it turn on when the charger is connected?
Does it indicate that it is charging when the charger is connected?
完成的
It doesn't indicate if it is charging or receiving power and power button does not indicate that power is being received.
完成的
完成的
@mskillerboss
Try what is suggested in the Most Helpful Answer below.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @malice9182,
It seems as though there is no power getting from the charger to the laptop to either charge the battery or to turn it on.
This could be either a faulty charger or more likely a faulty DC-In jack - Lenovo part #01FR146 (supplier example only).
Sometime the centre pin connection in the DC-In jack breaks internally due to frequent insertions and removals of the charger plug. If this is the case the DC-In jack has to be replaced as it cannot be repaired.
First check if there is 20.5V DC on the cable plug of the charger.
If that is OK next you will have to open the laptop and use an Ohmmeter to verify that both the +ve and -ve connections through the DC-In jack are OK from input to output.
Here's the hardware maintenance manual for the laptop.
Go to p.45 to see how to remove the systemboard, so that the jack can be tested and replaced if necessary. If the jack is faulty, search online using the part number only to find suppliers.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
JumalHarrigan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 2,032
