跳转到主内容
加入维修社区 - 创建账户
Google 第三代 Pixel 系列智能手机,也是其首款“刘海屏”手机。配备 6.3 英寸 QHD+ OLED 显示屏,提供 64 GB 或 128 GB 存储空间。有“纯粹白”、“只需黑”或“非常粉”三种颜色可选。
Part for insulation tape?
Changing my battery due to the phone overheating and I noticed the insulation tape was torn. I cannot seem to find a replacement part for this anywhere. Can anybody point me in the direction of the part or a workaround to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi
I wouldn't worry too much about this tape as it docent appear to be connecting to anything,heres what I would do!
try your best to straighten it out and get some non-conductive tape such as sellotape or electricians tape to put on top any that should fix your issue the best I can be fixed as I don't know of anywhere that would sell you a custom cut piece of this type of tape.
if you have anymore questions please ask
hopefully this helps
这个答案有帮助吗?
得分 1
7条评论:
This is what I was thinking of doing but had one thing holding me back. That insulation tape seems to be connecting to a heat sink from the battery to keep the board cool. Will electrical tape be able to transfer the heat from the battery to that heat sink?
完成的
@Justin O
I don’t think it would matter too much as tape is horrible for transferring heat(that sort of thing wouldn’t make a difference in a cooling system)when its that thin,I think the tape is more just part of the manufacturing process rather than a essential part of the phone so the electrical tap will do just fine:-)
完成的
Thanks, going with the electrical tape for this!
完成的
@Justin O
That great:-)
完成的
I tried using some metal foil tape, thinking it would conduct heat better, but now my GPS isn't working. I think the foil is shielding, reflecting, or otherwise interfering with GPS satellite signals. So don't use metal tape!
完成的
显示更多的2条评论
添加一条评论
To anyone else watching this thread, this isn't regular tape. This is a graphite thermal pad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 785
