跳转到主内容
加入维修社区 - 创建账户
2020 年发布。型号名称 GeForce RTX™ 3060 Ti VENTUS 2X OC,图形处理器 NVIDIA® GeForce RTX™ 3060 Ti,接口 PCI Express® Gen 4,CUDA® 核心 4864,核心频率 Boost:1695 MHz,显存速度 14 Gbps,显存 8GB GDDR6,显存位宽 256-bit,输出。
Thermal Pad replacement thickness
Does anyone know the thickness of the thermal pads?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Unfortunately, I cannot find anything on the specific thickness of the thermal pad, but I did find an article on finding the best fit for your GPU. I'll link it here for your viewing, but I'll give you the spark-notes of it.
Ideally, you should use the thinnest thermal pad that you can with the device. Start with a 2mm thermal pad, and if it has an indentation from the heatsink go down a size of thickness. The material that you use also matters, as some materials dissipate heat better than others.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
João Fonseca 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 79
总计 6,802
