跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Laggy macOS, compared to my iMac from the same year
I have a Mid 2012 MacBook Pro with a GT650M/Intel HD 4000 and a 2.3GHz i7 and a Late 2012 iMac with a GT675MX and a 3.2GHz i5, opening the applications folder in the dock and scrolling thru websites on chrome seems way laggier on my MacBook, i know its older but i didnt expect it to be that much laggier
Both running Catalina 10.15.7
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
Iv seen this happen a couple times when installing macOS Mojave and it’s usually fixed by reinstalling the OS however if this doesn’t work it may be something more hardware related
I would also try closing all runnings apps and try a pram reset (here’s the guide)如何重置Mac笔记本电脑上的SMC、PRAM和NVRAM
Hopefully this helps
这个答案有帮助吗?
得分 1
4条评论:
Thanks, ill try that
完成的
@danby
Good luck
I also added a link to how to reset your SMC and pram as this can also cause it:-)
完成的
@hellomacos - @danby is already running a newer OS so jumping to the older Mojave OS won't help here "Both running Catalina 10.15.7"
完成的
@danj
Sorry
I must have worded it unclearly
I meant from my experience I had this problem when upgrading to macOS Mojave so what I was suggesting was he reinstalling macOS Catalina (the OS he is currently on)
完成的
添加一条评论
@danby ‒ I suspect your Mid 2012 Unibody MacBook Pro is still running with a HDD vs your Late 2012 Retina MacBook Pro which has a SSD.
Spinning disk drives are slower than solid state drives! More so as the drive is used as unlike a SSD the files data blocks tend to get fragmented across the platters which causes the drive to work harder to find the fragments before it can show you what it is retrieving.
A second factor is RAM, as you didn't tell us what your systems have that too can effect things! In the case of the HDD system when you don't have enough RAM it will leverage the drive for Virtual RAM so now that HDD fragmentation effects things here too! So running heavy RAM tasks (like web browsing) gets messed up to!
To get better performance I would upgrade the HDD to a SSD as well as boost the RAM if you have anything less than 16GB.
One warning here! The HD SATA cable should be replaced as well. The original cable was only rated to SATA II (3.0 Gb/s) data rate whereas your new SSD will push the cable much harder than what the old HDD did. You need to upgrade it to a SATA III (6.0 Gb/s) rated cable. To add to this the early versions of the better cable had some issues as such they too need to be replaced! If you don't you'll end up chasing your tail with performance issues which won't make sense. As the data flow rises the flow will have CRC errors causing the retransmission of that given block stream. But it won't be a one time even it will end up in a loop condition over and over again! Your system will heat up as the CPU is fighting it out with the drive where the middle man is the guilty party!
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable and the guide to put it in MacBook Pro 15" Unibody Mid 2012 Hard Drive/IR Sensor Cable Replacement
Here's a bit more on the failing cables Your Hard Drive Cable Is A Ticking Time Bomb
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable图片
产品
$19.99
这个答案有帮助吗?
得分 0
4条评论:
i'm on a base model mid 2012 retina, with an SSD of course, and yeah its probably the RAM, it only has 8GB compared to my iMac with 32GB
完成的
Also another thing its not slow to load the folder in the dock, the animation is just laggy
also i didnt know about the HDD cable thing, thats good to know since i have a 2011 unibody with an ssd in it with the normal cable, ill probably replace it if i put a better SSD in there since its only a 120GB WD Green
完成的
@danby - The wording of your question implied the Unibody system was slower, is your retina system the slower? If that's the case then your SSD likely doesn't have enough free space. A rule of thumb is smaller SSD's 128 & 256GB should have 1/3 of the drive unused. 512 and larger (2TB) only need 1/4 unused.
Sadly 8GB of RAM also effects things.
完成的
I'm talking about the retina the unibody isnt in use at the moment and is unrelated, i have about 150GB of space left, its probably the ram ill get a new machine, or go back to my 2020 MBP
完成的
添加一条评论
添加你的答案
Dani 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 4
总计 90
