跳转到主内容
加入维修社区 - 创建账户
2018 年发布的 Acer Predator Helios 300,可通过多个型号进行识别。大多数指南适用于所有型号。
Acer Laptop Keyboard Issue
Hello, I’ve some problems with my keyboard.
I have a Acer laptop that I purchased a couple of years ago and it does not store the L, K & spacebar keys while writing on documents.
I’ve to press those keys several times for it to work. I am a little bit confused, is it a mechanical problem? Or a software issue? Should I need to replace my keyboard? I am unable to fix the issue.
Any help should be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
This might be the issue because of carbon or short-circuit in the keyboard. Thats why the some keys were not working. If this is due to carbon, then you can open the keyboard and clean it with dry cloth and most probably it will start working again.
To do so, find all the defective keys first from keyboardtester.io and then plug them out. After that take some alcohol (don't use water) to clean it.
It will help you to fix your keyboard. if this don't work then it might be the issue from motherboard circuit. Then you need to repair it or maybe need to buy a new one.
这个答案有帮助吗?
得分 2
添加一条评论
those keyboards are capacitive or resistive keys. For resistive, you push a carbon pad down on top of two pcb traces. The click is generated by the mechanism and not by the switch. That is silent. Desktop keyboards are much larger and can usually be taken apart to clean surfaces and revive the switch function. Laptop keyboards MIGHT be fixable. New keyboards are relatively inexpensive.
I would research a source for a new one, then attempt to disassemble and clean the old one. If it doesn't work, order the new one.
这个答案有帮助吗?
得分 1
1条评论:
Should i need to change the PCB traces then? Is they available in the market?
由完成的
添加一条评论
Hi @shreyamathur651
Thinking to replace the PCB traces that were placed on the motherboard of the keyboard. Tried keyboard tester tool as well and found that some keys were not registering.
It might be some issue with my keyboard only. Thanks for your help.
这个答案有帮助吗?
得分 0
添加一条评论
It could be either a hardware or software issue. Here are a few things to try:
  1. Restart your computer: A simple restart can sometimes fix software glitches that might be causing the keyboard issue.
  2. Clean your keyboard: Dust and debris buildup under the keys can interfere with their functionality. Try using compressed air to clean your keyboard.
  3. Update your keyboard driver: Outdated drivers can sometimes cause keyboard problems. You can update your keyboard driver through Device Manager.
If none of these steps work, then it's more likely a hardware issue and you might need to replace your keyboard.
To check if all your keys are working, you can try using a free online keyboard tester tool like bestkeyboardtester.com. This will help you identify any other problematic keys.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harris brown 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 74
总计 4,211
