跳转到主内容
加入维修社区 - 创建账户
Logitech G533 无线游戏耳机的维修与拆解信息。G533 可通过型号 A-00072 进行识别。它于 2017 年 1 月发布。
Mic doesn’t work
My mic doesn’t work all the time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
My guess is an intermittent mike may be the result of wire damage. You may have to carefully disassemble the headpiece containing the mike and wiring to examine for wire damage, especially at the point(s) of flex. If visible wire damage isn't seen then a continuity test to each wire of the mike is needed to determine which wire broke inside insulation. Soldering skills would be needed to repair wire damage. If you find and repair damage, try it first before reassembling everything, exercising mike movement to ensure the repair is complete.
由完成的
添加一条评论
1个答案
This is not a good question because it gives no history or info relative to when and what was tried to troubleshoot it.
Best guess is a broken lead wire, usually close to an end or connector connection.
Least likely is something internal to the headset unless the mike boom has been move a lot to extreme positions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
afyuqnjklpi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 40
总计 3,923
